1 - 11 of 11 Posts
does anyone know how to get the shifter knob off my 85 with the 5 speed im thinking its pressed on or something cuz it wont unscrew
Never tried removing mine...but there is a hex head under the shifter knob, you may have to isolate the shifter itself with a pipe wrench, then use a open end wrench under the shifter knob.
theres no nut under my shifter knob
No longer a pizza tech.
if its factory, there should be a nut. If its the factory knob with no nut it will screw off. The stick is threaded on down under your boot also, that might be spinning. Best bet is to hold the stick with something while trying to take the knob off. sometimes they get super stuck on.
I tried getting one off in a vice. the threads were so rusted together that the threaded insert inside the knob was spinning.
Ok well I know about the threads down on the bottom I've had the stick out and tried but I will try in a vice
ok well ill have to try putting it in a vice when i got to my grandfathers cuz my dads isnt bolted to a workbench rightnow and try to take it off
Discussion Starter · #10 ·
ok will do once i get over this cold
Discussion Starter · #11 ·
well i got her off it was pressed on thanks guys
1 - 11 of 11 Posts
