i want a t-type grip shifter knob for my 2.2L 5 speed. but i can only find ones for a regular automatic. I dont want to replace the whole shifter and crap. just the knob if possible. thanks
what year truck? if its 82-97 knob just unscrews but if it a 98+ the knob has to be cut down the center ,for example think of this as the shifter (I) <knob
you have to cut it in half( were the I is) and peel it off, you may have to grind down the shifter inself depending on the size hole of the new knob, P.I.T.A but worth it, just get a shifter at a junk yard from a 94-97, its a lil taller but some like it
i saw this on a few posts. but i then i thought...couldnt i cut the knob off and instead of grinding the whole thing to a smaller circle couldnt i drill a hold in the middle the size of the hole in the new knob and just put a screw without a head into both? of course after threading the shift rod.
The Blue Pwns Joo!
Maybe if you make one more thread about this you'll notice that nice shiney search button in the upper left corner...
