Hey All,
Ok well I am going to start this real quick (next week or so).
I have a 1993 grille for my 1990 s-10 (still need rad. core support) but I am going to shave the corner lamps in the grille.
I am going to get a set of lamps to use as a fill panel for the hole.
My questions are:
How do I secure the lamp...will the way it mounts facotry be enough? Should I use fiberglass resin to fill as much as I can?
Then once I have the lamps mounted I know it is lots of sanding, but can I use fiberglass filler? Should it stick good to the grille?
Then how should I prep the grille for painting? Not sure since it is the plastic/fiberglass stuff.
Thanks,
Scott
My questions are:
Thanks,
Scott
