1 - 19 of 19 Posts
True Ambition
Hey!
Is there anyway to get the forth bolt without a special tool?It isnt actually a bolt it is a flat disk with the * type patten. I tried a regular screwdriver and a wrench but it keeps slipping and I don't wanna strip it. I have a 2000 sonoma with factory bucket seats. The bolt is the center rear which also holds the middle passanger lap belt and is the fourth bolt for the drivers seat.....they always have to throw in one damn tricky bolt or something!!! If I have to go to the upholstry shop then so be it UI can bs him about getting the seats covered and then say by the way can you take this off?
Thanks
want my #... 911 beotch!!
sorry to be absolutly no help, but i need to know too. i am replacing the set recliner thingy on the drivers side and i need to unblot the seat
ZQ8 Sonoma Owner
Is this a torx bolt you are talking about? Thats all I could think of with the star pattern. My seatbelts were held on by a torx bolt, so that may be what you guys are talking about. Look into that.
Greg G.:)
Greg G.:)
cool, thanks man!:thumbup:
If it's a seat belt bolt it will be a torx head. They do that so people won't monkey around with seat belt mountings and some of the bigger torx heads are not common in most peoples toolboxes. Torx heads are a b*tch because they strip easy. Make sure you have the exact size.
OK, that bolt will probably be a huge *****. Somebody has a tendency to put too much loc-tite on them at the factory. We had to heat up the collar around the bolt with an acetelyne (sp?) torch and use a pneumatic impact wrench to get it loose when I was swapping out my seats. It's just no fun at all. I advise that you go to your local hardware store and get a new bolt because the threads are gonna be gunked up when you go to put it back in. Make sure you put some good lubricant on it, too, to make sure it doesn't seize up again. Let me know how it goes.
Jeff
I'm having the same problem here. I want to remove my bench so I can put in my 2 12" enclosure in the xtra cab. I went to sears today and they didn't have a torx head that big. Anybody know what size it is?
Thanks,
jay
Should be either 40, 45, or 50 - I'm thinking 50 since we broke our 45 on a Jeep and I didn't need that particular one . . .
Jeff
I'm pretty sure it's a T-45 and mine wasn't that tight so who knows.
ZQ8 Sonoma Owner
Yep,
Got my big ass torx bits for a 1/2" drive at Autozone!
Greg G.:cool:
Gingerbread Man
I ran into same problem when I was running all my wiring for my stereo. I found the you can take a regular allen, find the closest size that will fit in the torx screw, and crank away. It helps if you have the allens for a socket wrench. Trust me it will work.
Good Luck
low-blazer said:
Yeah, that'll work a couple times...till the head strips out...then you're focked:thumbup:
more like royaly focked!:bash:
Gingerbread Man
Well, then I guess I was a lucking focker, because it worked for me a couple of times.
:D :bah: :thumbup:
Allright,
Since no one is helping out on the size, I went out and sized it. It is a T50 torx screw.
Thank you , Thank you,
Jay
1 - 19 of 19 Posts
