I am doing a sbc 305 swap in my 2.8 s10 i am installing a th350 what do i need to for a crossmember on trans can i use stock or what mods do i need to do or should i do aftermarket crossmember swap?
Vandelay Industries
You can use a stock automatic crossmember. Depending on how you position the motor, you may have to move it forward/backward and/or cut off the stock mounting pad and weld in some new ears and a plate to mount the th350 to
i saw what you did there!
yeah just slide the crossmember no big deal
i have a 5 speed crossmember can i use it and adjust ot or do i need a trip to junkyard for auto crossmember?
You can use the stock 5 speed, I used it on my 88. You just need to slide it foreward. On my truck, the holes lined up in the frame.
