21 - 40 of 85 Posts
Discussion Starter #21
Dragginbody said:
that would be awesome. both of mine leak at the head.
look slike that is part of the case and not a rebuild so not any one has them as a part. but I would buy a junk one and use its parts :(
or maby call sanden.
Discussion Starter #22
here ar the comon parts,
http://www.sanden.com/parts/sd5.html
Work in Progress!!
how are the SD 709's and how hard would it be to put one on my 95 2.2 s10? i think i would probably be able to get one for nearly nothing if i think i will be able to put it on my truck.
ITS NOT EASY BEING EASY, MODERATOR
i mounted 2 on my 94 2.2. u can modify the stock ac location and bolt a sanden right up.
Discussion Starter #27
get laid/commit suicide
i'm confussed about the oiling system, it looks like you are basicly mixing the oil the the air going in, which i understand, but how do you get the oil back out of the air so you can send the air to your tank?
Discussion Starter #30
I converted mine to greese , nice clean oil free air out ;) and no oiler :)
more details when I get home.
Completly Useless Truck
WTF?:screwy:
Discussion Starter #34
cali_ryde said:
wow greese?!? i need this info, im sick of worryin about the oil on my york. prolly gonna switch to a sanden this summer.
lol,
I am working on the test numbers still,
but I blocked all origional oil passages and ripped it completely apart and removed all oil, tne coated all joints with greese and filled a little into the crank case and cyl walls,
I am going o stick a hour meter on it and just let her run till she gets supper hot or locks up to see what will happen,
but I will post up the vid soon, showing the oil just flying past the piston rings,
it is so sad.
Discussion Starter #35
Discussion Starter #37
DailyDrivenDime said:
did you write that or find it?
I wish I did lol,
Found it on Sanden's web site.
Discussion Starter #40
21 - 40 of 85 Posts
About this Discussion
25 Participants
impalaon666z
S-10 Forum
Full Forum Listing
