Hey guys I had an issue with the vapor canister for the fuel tank... fuel was coming out of the purge valve and we tested the purge valve it is fine but the vapor canister was plum full of gasoline. What is causing this?
super old design of fuel filler, and not reading owners manual that says don't top off when refilling.HWhat is causing this?
That would make sense thank you!super old design of fuel filler, and not reading owners manual that says don't top off when refilling.
