1 - 20 of 38 Posts
I'm taking a 305 with a th350 and putting it on a 2000 s10 with 4x4 but I took the front diff out. I will be putting a 50 plymouth special deluxe body on it. My question is there anyone out there that has done this with similar years and what do I need to do to avoid problems when swapping because I don't want to take this thing off and on 15 times any advice will be greatly appreciated
If it's going to be a driver/cruiser, I'd get a 700R4. Your engine, gas tank, and wallet will thank you.
Make it easy on yourself and find a two wheel drive chassis to use. It will be so much nicer in the end and won't look like an abortion.
time to get cereal
I would say a good 99% of the people who regularly post on here right now have only had S10 bodies on S10 frames, lol.
Ya I just wanted to try and get my great grandpas car going again I have plenty of automotive and welding and fab skills just no direction.
Boozebag
I think you are going to need an S10 long bed chassis. That rig is pretty looong...
which one...
Mo, wasn't Joedoh on another forum? I don't remember
Registered Hoosier
which one...
Joedoh was on the 67-72 chevy truck forum, but I haven't been on there in a while, so I don't know if he is still active.
Reactions: Mostizzle
Discussion Starter · #14 ·
The hamm just says don't do it use the original frame but I'm too far into this one and I want all wheel disc breaks
time to get cereal
I don't get on that forum a lot but I have seen S10 frame builds on there... you might have to search around.
Like it has already been said though, a 2wd frame will be a much better candidate for what you are trying to do.
This site would be more help. it's for Chrysler products from the 30's to the 60's.
This one you should find helpful
Discussion Starter · #20 ·
depending on what your plans are, i'd leave is stock if it was mine.
I would love to leave it stock but for 4000 just to rebuild an engine isn't in my budget. I picked up the roller s10 for 200 and 300 for the engine and trans so I thought it was a steal so thats what I'm dealing with. I didn't know how much of a big deal 2x4 vs 4x4 was on these s10s if I have to modify things I will. im a pretty good fabricator but like I said before I would like to know what problems I might have with the firewall and trunk before I start swapping the body
1 - 20 of 38 Posts
