Ok, guys, I have a treat for you all. A while back, I stumbled upon a COMPLETE service manual for the S-series trucks. I believe these are GM manuals as they go into crazy step-by-step detail with the complete procedure and torque spec documentation. The PDF files were broken up into sections so that I will post them in the appropriate areas. If the following links do not work, let me know, and I will try to correct them. Make sure you have flash/java and all that updated on your browser.
Here is a link to the complete service manual that I uploaded. This includes everything from electrical to engine and suspension as well as body.
https://skydrive.live.com/redir?resi...CQUOw603XC--lY
CHARGING SYSTEM
CHARGING.pdf
THE ELECTRICAL COMPONENT LOCATOR IS VERY HELPFUL
ELECTRICAL COMPONENT LOCATOR.pdf
FUSES
FUSES.pdf
LIGHTING SYSTEM
LIGHTING SYSTEM.pdf
98+ COMPLETE WIRING DIAGRAM
Sonoma wiring diagram.pdf
STEERING COLUMN WIRING
STEERING COLUMN.pdf
WIPER WASHER
WIPER WASHER.pdf
DOOR WIRING AND POWER WINDOWS/LOCKS | COMPLETE PINOUT DIAGRAMS
DOORS.pdf
CHARGING SYSTEM
CHARGING.pdf
FUSES
FUSES.pdf
LIGHTING SYSTEM
LIGHTING SYSTEM.pdf
STEERING COLUMN.pdf
WIPER WASHER
WIPER WASHER.pdf
DOORS.pdf
