Ok guys i have a treat for you all. i stumbled upon a COMPLETE service manual for the S-series trucks a while back. i believe these are GM manuals as they go into crazy step by step detail with full procedure and torque spec documentation. the PDF files were broken up into sections so i will post them in the appropriate sections. if the following links do not work, let me know and i will try to correct it. just make sure you have flash/java and all that updated on your browser.
here is a link to the complete service manual that i uploaded. this includes everything from electrical, to engine, and suspension as well as body.
https://skydrive.live.com/redir?resi...CQUOw603XC--lY
ABS BRAKES. full electrical breakdown, module, and wire routing.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!128&authkey=!AGZKL0eiQq5LH9A
DISK BRAKES full torque specs and servicing inside.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!133&authkey=!AB2JNwELCf2eqMg
anything else that may be suspension related is in the suspension section or just click the main link up top in my post for the service manual directory.
