Status
Not open for further replies.
· Tech Mod
Ok guys i have a treat for you all. i stumbled upon a COMPLETE service manual for the S-series trucks a while back. i believe these are GM manuals as they go into crazy step by step detail with full procedure and torque spec documentation. the PDF files were broken up into sections so i will post them in the appropriate sections. if the following links do not work, let me know and i will try to correct it. just make sure you have flash/java and all that updated on your browser.
here is a link to the complete service manual that i uploaded. this includes everything from electrical, to engine, and suspension as well as body.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!117&authkey=!ACQUOw603XC--lY
below is the COMPLETE 4.3L engine rebuild. first 10 pages or so has the full torque spec for every nut and bolt on the motor. the rest is the step by step disassembly/assembly in full detail, complete with exploded view diagrams of every aspect of the motor, even bell housing measurements.
872 pages long, 134MB in size.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!146&authkey=!AMSFEG4w7I-_28E
here is the one Crew Cab Sonoma found.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!121&authkey=!AF48JmRCmdV2UJk
this one is about the 4.3 cooling system. radiator, oil cooler lines, etc.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!136&authkey=!ANzkqCjcCuuwu1k
for the starter. a tad bit of electrical pinout too, as well as how to test.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!157&authkey=!AEsrrPsP4hel8nw
NON VOTEC 4.3. not as detailed but still informative.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!120&authkey=!ALqbRRfSZ4ci3o8
· Tech Mod
Re: S-Series Service Manual.
^ i'm assuming they worked for you? like the main link on top?
· Tech Mod
you had to log into skydrive? should be able to download without it, at the very least view it.
Status
