1 - 1 of 1 Posts
The Static Drop Experts
S-Series Transmission Spacer
To help correct driveline angles our transmission spacer will raise it aprox. 3/4"
Material: A500 .120 STEEL
Finish: BLACK POWDERCOAT
S-Series Center Support Bearing Spacer
To correct driveline alignment the center support bearing should be raised 1".
S-Series Axle Set Back Plates
By using Set Back Plates you can relocate your rear axle rearward approx. 1/2".
Material: A36 STEEL
Link for more information/ordering
http://thesuspensionsource.mybigcommerce.com/the-suspension-source-11/
1 - 1 of 1 Posts
