unfortunately the first two times the bearings went(second time due to the fact they didn't replace all the bad bearings the first time, so after 6 days had to be taken back off and sent in again). Everything was stock for the blower, no increased shift points, original intake that came with it, and stock pulley. Then 10 months later they failed again, now powerdyne wants $500 to fix it, and from the first time how can i trust them with my money since they charge $100 just for opening it, and then add on another $40 for shipping..
So i took it upon myself to do the bearings, unfortunately i did not use enough bearing seater on one of the bearings, it shook loose and the impeller is ruined. Probably cost about $800 to fix it now. It is tempting cause i do sorely miss the power gain, but it would just be re-accuring problems. And $1,400 would buy me a new head unit.
I really try to not cut powerdyne down, but i can't help it. Maybe i will sometime buy a new head unit, since $1,400 is still alot cheaper than the next nearest kit.
