I have a 1993 S-10 2.8 liter and needed to do a "panic stop' to avoid hitting another car. I did this by down-shifting and pressing the brake pedal really hard. Luckily, I stopped in time, but the truck engine will not re-start. The engine turns over, but will not "fire". Is there a "bump stop" switch located somewhere which would have disabled the fuel pump? If so, where would this switch be located? Any help would be greatly appreciated.
John 844
ASE certified MasterTech
No inertia switch, sorry.
Start checking connectors and grounds. You may have dislodged a connector.
i saw what you did there!
hum thats crazy
yeah gm dont use that switch instead they use oil pressure switch on engine in rear top by distrib
definitely check all wiring connections including at battery etc
do you hear the FP prime up a few seconds when you put key in run position?
if not then check relay and wiring
beat on tank with a big rubber mallet
check for 12 volts at orange wire at relay socket all times even key off
jump orange wire to gray wire there
it is on driver side by brake booster up high
pump should run and truck should fire up with these two wires jumped together
if it does then bad relay or fuse
if pump runsbut still no start then it probably ignition problem
chck cap and rotor for being worn burnt
The engine will run even with 0 PSI. oil pressure, don't beleive me, just unplug your sending unit.............
Not sure what you are talking about?
The clutch switch would not allow even engine cranking.
