1 - 2 of 2 Posts
I have a 1999 S-10 with a 2.2 ltr engine with a blown head gasket.
I have removed the cylinder head and then decided to take the block out and just overhaul the whole engine.
My question is: can I assemble the engine with intake and exhaust manifolds on the stand and then slip the engine in, connect the transmission and the the motormounts OR do I need to remove the transmission and assemble it to the engine and install the engine/transmission as a single unit?
I ask because the transmission-to-engine bolt could not have been removed without removing the cylinder head.
suggestions, please.
John
· time to get cereal
The bell housing bolts are removable with the head attached...
It's easiest to leave the transmission installed, and drop the engine in with as little attached to it as possible. I usually leave the exhaust manifold attached to the exhaust during removal and installation.
1 - 2 of 2 Posts
