1 - 2 of 2 Posts
not a self portrait...
im in the process of removing my stupid lighted visor from my truck. when i took off the visor, on one side all around the one hole it was bubbled up with rust. to remove this, do i just sand it down to the metal, primer, repaint&sand etc.., or is there more than that when dealing with a rust bubble?
"I Like Mine With No Shine"
If the rust hasn't gotten into the metal and ate it up yet, then i would just sand it down, or grind it down until all of the rust is gone. then use either fiberglass or bondo over the hole, it depends on how big the hole is as to which one you should use., sand it down smooth, prime and paint.
1 - 2 of 2 Posts
