Is it possible to have your system pressure tested?
Can you see any fluid on the ground after driving it or anywhere on the engine? I would check around the water pump (may be losing it through the weep hole, indicating bad pump), near the thermostat housing, and along the overflow line. Check for breaks in the radiator near the seams around the top and down the sides.
How does the oil look? If it looks cloudy or milky, you may have a blown head gasket and even though the radiator looks to be the same level, it may be leaking fluid past the head gaskets and being replenished by what's in the overflow bottle, accounting for the loss.
