what is the spline count on my stock rear end? will the richmond 373 gears work in mine for a 2 series or do i need the set for a 3 series carrier. my truck originally had 342s and i had the 373s from slp put in and when my driveshaft broke it bent my pinion. i was in a hurry to get the new set so i ordered on summit the richmond gears for a 2 series carrier pn # RMG-4900071 i think i need the pn# RMG-4900461 for a 3 series. they are also both 27 spline. i need my truck back ASAP. thank you
Rocky
LEAD FOOT LARRY
You need the 3 series gears.
If you can use the Zexel again it is a 3 series carrier.
If you are using the original carrier it will also be a 3 series carrier.
The axle spline count only affects the spyder gears.
If your Zexel was not hurt you have no problem.
ok i had to send the wrong one back and ill have the right one wed. sucks cause i had a feeling it was a 3 but i was in such a hurry to get my truck done this is what i get i guess. the diff cover isnt off yet. MAN i hope the zexel is ok and its just the pinion. what a pain this is. dont want to know what the bill is gonna be for all this.
hahaha i guess my bro wa son here last. the post above is really me.
Rocky
