Can anyone help? I want to get rims that will have a backspacing large enough to bring at least the sidewall of the tire out flush with the widest part of the fenders. If I do this on front AND back, I'll need two different pairs of rims ... one pair wider for the back ... Right?
Also I have a site for a Wheel Calc. but I'm not sure what offset (mm) my rims are now, which would help in estimating what I need to buy. I suppose my question, in part, is ... Is the "offset in millimeters" the same thing as the measurement of the "backspacing in inches"? And if so, would having a 2" drop in front cause problems when I went to put a 17x9 wheel with 245/50 tire? [... I'm pretty sure it's 2 from what some guys told me at Xtreme Auto in Bartlett, TN. (Check that place out) If from the pic, mine doesn't look like 2", let me know. It was like that when I got it, and they focked it up by cutting the springs.]
From using the calculator below, I see I get some spread and slightly taller tire diameter from what I have now (which is ok b/c the rim/tire combo now is shorter than stock by about a half inch), if I change my offset by -13 or -14 mm.
Can anyone help?
Thanx in advance for anything.
Can anyone help?
