Wow - that S15’s gorgeous!!
For the S10…uh…
if you’re comfortable with all the wiring then the cheapest route would be to get a stock 1988 2.8 ECM with pigtail from eBay. You’d also have to get an instrument cluster with the cable-driven speedometer and VSS (here’s a terrible example:
1986-1988 CHEVY S10 SPEEDOMETER INSTRUMENT CLUSTER 25078792 | eBay). That assumes all of your sensors and accoutrements are working. (so maybe it’s not the cheapest).
The simplest route would be to put the Edelbrock intake and a carb on it as others have stated. I do have the Edelbrock base (used) and a 2 bbl riser (new) that I could sell for $400 (note that some carbs will mount “sideways” with the front of the carb facing the fender). You’d need to get a gasket for the riser and probably a carb adapter. And you’d need to get a stand-alone torque converter lockup kit and manual gauges. Cruise control is probably a goner without the stock speedometer with the VSS output.
If you have a carb that will work with the Edelbrock intake then the costs even out a bit. I’m sure I’m missing something, but that’s what I can think of at this point.
For the S10…uh…
