Just bought an 86 2.8L V6 Blazer 4x4 off of a friend and I'm fixing a few problems. One is with the driver-side brake caliper. The bolt that holds it to the steering knuckle was loose and it turns out that the threads on the knuckle had been stripped. Some crappy shop had tried to tap a nut to the other end of the bolt to hold the caliper together, but the brake pads weren't even making contact with the rotor and this was causing excessive work for the other side caliper and overheating the brakes on that side.
So, I need to replace the driver's steering knuckle. Any suggestions on where to find the part -- I guess a junk yard, right? As far as replacing it, it looks like I have to drill out the rivots holding the balljoint to the upper arm and replace the balljoint, as well. Is this correct? Is this a difficult procedure?
Thanks,
Brian
Thanks,
Brian
