I finally got tired of the coolant leaks from my lower intake manifold, and bought the gasket kit from Auto Zone. Did the job this past weekend, started Friday evening and finished up Saturday afternoon.
This is a quick overview of the job. This is by no means a complete and concise instructional. Refer to the GM Service Manual as I did or a good Chiltons manual. This is a somewhat involved job and should not be attempted if you are not mechanically inclined (Disclaimer finished).
Here goes...
Clean the LIM of all crap and solvent wipe all mounting surfaces.
Install the LIM gaskets to block as shown
Apply silicone sealant beads as shown to block ends
Install guide pins (optional) loosely into block and place LIM onto block.
Apply blue loctite to bolts and tighten in three sequential steps:
5 6
3 2
1 4
7 8
FWD
Install new fuel pipe O-rings before re-installing the fuel pipe.
Re-install everything back as per the shop manual.
Give the silicone 24 hours to fully cure before adding back the coolant and running the engine. It also would be best to do an oil change after this to remove any foreign matter than may have fell into the block valley when the LIM was removed.
Sure it's a lot of work, but you can save a bunch of money doing it yourself and get the satisfaction that you spent the time to do the job right. It was also a good time to really clean the engine up, part by part, before putting it back together.
Now go get greasy!
Bill.
Here goes...
- Drain the coolant. Best done when engine is warm to keep the thermostat open for complete head draining. Remove the Thermostat goose neck and coolant lines leading from the LIM (Lower Intake Manifold)
- Disconnect the battery.
- Remove: Alternator, EGR valve, Coil pack, Throttle cables and brackets, Distributor (Note: Remember to mark position of the dist. housing to manifold and the position of the rotor).
- Loosen the A/C - Power Steering Pump aluminum mounting bracket, slide assembly forward toward fan shroud to clear the LIM.
- Remove and move aside the EGR exhaust feed pipe at the LIM.
- Remove the Brake Booster hose, PCV hose, etc...
- Remove fuel feed pipe from injectors and supply lines at firewall (watch those two O-rings that are at the firewall connection).
- Remove all electrical connectors from their terminations (MAP sensor, EVAP purge valve, Throttle body, etc...)
- Tie main wiring harness up and out of the way.
- Remove the eight LIM bolts. Gently remove the LIM as an assembly.
- 3 lb./ft.
- 9 lb./ft.
- Final torque, 11 lb./ft.
5 6
3 2
1 4
7 8
FWD
Now go get greasy!
Bill.
