1 - 13 of 13 Posts
Hyundai Owner
Be sure to get new door pins. I didnt replace mine when I swapped doors and one of the bushings is now broken and I have to slam the door to shut it. Theyre only $5 or so each.
Hyundai Owner
Any parts store has them in the HELP section.
Youll also need a spring compressor for the door springs.
Can Yah Hear That China!
would broken bushings be the cause for having to slam my door shut and an awful metal on metal screeching noise whenever i open/close it?
Hyundai Owner
Its possible. i have to slam my drivers door because it wont latch due to a bad bushing. If I pound the pin up where its supposed to sit (the pin drops), the door shuts normally. Mine doesnt make noise though.
i noticed mine on makes noise in the cold (latley its been 32 degrees almost) so i figure it squeeks cause of the cold. i';ll see if that pin is loose or not, maybe this is a good excuse for suicide doors? :shrug:
Truck is toast :-/
i've got a completely ****ed hinge. i just accept it. on that note, my door spring fell out again today.
1 - 13 of 13 Posts
