I wired up my underhood fuse block c2 as described, however, now I have another issue that has me baffled...Hopefully some of you have a fix or wouldn't mind pointing me in the right direction. Here is the issue: When the key is in the "RUN" position everything works fine (fuel pump primes, all interior accessory powered devices work, engine fires up when "START" etc, etc) BUT if I put the key in and just turn it to the "ON" position, there is no power to the radio or gauge cluster lights.....Opposed to before I rewired the underhood fuse block c2. I would appreciate any help!
Also, I almost forgot, the headlights....Shouldn't the headlights come on when the key is turned to the "RUN" position? IIRC they used to before but don't now.
