any suggestion on how to remove a sticker from a lexan window without scratching it? the ssf sticker is kinda out of date now.
on plexi?!?!? wont that scratch?Weasel said:just use a razor blade then use some windex or just use your fingernails and then use some windex.....
EXACTLY!Nates93sTEN said:Why, that forum is still up? It's more active than this one thus far.
lmao!! nah, it was just the fumes collecting in your truck!Z10 said:the adhesive will wipe off with some 3m adhesive cleaner on a rag. i used it to get the old glue off from my window tint. **** came off so easy i about had a orgasm.lol
not on plexi tho, it will warp the plastic.........964pt3 said:The safest and easiest way to remove ANY decal or sticker from and auto body is using a hairdryer. Start by heating one side until hot, then slowly start to peel it while heating up the next section. You'll find it takes off everything and no cleanup is required, except this area will now be cleaner than the rest.
