1 - 2 of 2 Posts
Hey, I was just wondering if any of you knew how to remove the smallest leaf in the rear. Any instructions on how to would be most appriciated. If I were to remove a leaf how much lower would the truck be. Thanks.
Gingerbread Man
Hey,
My s10 current sits 4-3, and I wanted to bring the altitude down in the rear. I called around, (not going to mention supplier names)and I was told to just remove the center leaf, and i would see 1"- 1-1/2" drop. I did one side of my truck, and really didnt like the way it looked. So I called another supplier that I have used before, and the guy there about had a **** coniption. He explained that when you remove the center spring, that I would be creating alot of problems for my self later. He also said that removing the lower leaf really does nothing for the drop, except drop it the thickness of the leaf. My suggestion, go with and aftermarket mono leaf(belltech) or with blocks.
Good luck
Rob
1 - 2 of 2 Posts
