A Constant Work in Progress
when you turn yer truck on, draw or make note of where the needles are (ex. if yer gas gauge shows you have half tank, either take note that the needle is pointed right on half tank of draw a diagram)........then take the fork and slide it behind the middle/base of the needle and pull up.....it should come off.......when you want to put them back on, make sure yer truck is turned on........look at the diagram and place them back where they were......hope this helps
