Credit Bush
Hey guys, I'm removing my '01 door panels with manual windows. I checked the how to but Brian didn't post pics on manual windows. I've got everything removed except for the window crank clip. How do I get that off? Thanks guys.
I Like Fire....HaHaHa
There is a small C-clip holding it on. You may have to push the door panel in slightly in the area of the crank to expose it. Use a screw driver or a pick to either push or pull it off. Don't loose it thought. They can go flying it you're not careful. Once that is out, the crank will slide off a splined shaft. Make sure you have all bolts and screws removed from the panel. Don't try and pry it off. Prying it off could crack he panel just above the crank near the mirror.
