Here is a list of some parts and improvements that would make a noticeable difference for a Duke rebuild:
Start at the bottom...
1. Clevite 77 tri metal bearings
2. Balanced reciprocating assembly (important!)
3. High volume oil pump (some will argue this, but it has worked for me every time)
4. High end FelPro gasket set. Has the silicone blue oil pan gasket.
5. Chevy 350 flat top pistons. They have the same compression height as the stock dish 2.5 piston (pin to piston crown distance) and the same size piston pin too. You can buy a hypereutectic 350 piston for $16!!! Compression will increase from 8.5 to a little over 9:1.
6. Moly piston rings. Better than the iron ductile units.
7. Match port the head to gaskets. The heads on these engines are pretty close, but the benefit is there still...
8. Porting the intake/ exhaust runners. This can be tricky, you can actually lose HPs. If you knock off the valve guide sharp edges and blend the guide in the bowl, this usually helps flow and doesn't mess up the runners.
9. Cam. Oregon Cam grinders have several different grinds for this engine. They are great... you can actually talk to these guys and tell them what your requirements are, they will provide you with the right cam for your application.
10. Aluminum timing gear. This replaces the phenolic gear and doesn't shred. They are slightly noisier than the stock gear, but the long life is by far a better choice
11. Roller rockers. IIRC, Chevy big block rockers are a bolt on. There are different ratios, the Oregon boys are the best for recommending ratio choice/ cam combination.
12. Stock header... This is an easy one. Cut the stock header flange off,
(it's 1 1/2" in diameter) and weld on a 2 1/2" flange. This will effectively give you a performance header for cheap.
13. 2 1/2" exhaust - a muff shop can bend up a head pipe to cat for a 2 1/2" pipe.
14. High flow 2 1/2" cat. This connects right to the pipe from the header.
15. Performance exhaust:
Summit Racing® Cat-Back Exhaust Systems SUM-680031
16. If you are really going for it... a performance chip for the ECU.
These inprovements can give you an honest 120 HPs. Not much of a gain, but it makes an S10 Duke fun to drive.
Figure about $1,500 to $1,800 for everything - if you do most of the work yourself. It can be done for less if you shop around and don't go for all of the upgrades.
