Cheezeit9
I wanted to get a rear sway bar for my 95 S-10 2wd. I was thinking about getting one off an Extreme or something but wanted to know how hard it would be to put one on? What about from a blazer?? Would it bolt right up with the factory bolts and such on existing holes in the frame, if any? Would it be easier to use some off another 95 or would any year work? Any help would be appreciated. Thanks.
I have a 97 and got one off a Extreme and it bolted right on, it did come loose a few days later so I had a friend of mine just weld it to the frame, but it should line right up to holes already in the frame. Good luck By the way, its not hard to put on, hope this helps
yea It will bolt right in!!
dont get me wrong but I think the blazer and the xtreme both have the same rear sway bar!
Cheezeit9
ok, thanks for you help. So any blazer of the same body style will bolt up, am I right? The 94 and up?
look at this complete zq8 parts list the for s-10 trucks
you can use a 2wd blazer rear swaybar but for trucks you need to change the upper links on the rear swaybar.
Stabilizer Bar End Link (2)
unique to ZQ8; not from Blazer gm #15989670 around $30.00
for 2 links.
http://www.s10xtreme.com/zq8_suspension.html
