My 2002 s10 pickup rear windshield sliders are gone but the Glass is good , can I get a hardware kit or do I need a whole new glass ?
Sent from my Moto E (4) using Tapatalk
The seal around my 94 is dried out and cracked (but my glass is good), so I looked around at one point and gave up. Seems you can only get the whole window. LMC Truck has them for our models for $300. If you find out different, let me know.
is it factory or aftermarket?
Factory , someone broke it breaking into the trunk according to original owner . I'm thinking about putting a straight glass in because being a crew cab I'll never be opening it anyway .
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
use a piece of plexiglass- it won't break jagged like regular glass- and if you want real glass- pay the $$$ and get TEMPERED SAFTY Glass- it shatters into tiny cubes- the top rail is a little deeper than the bottom- slide up and the drop into lower rail- measure from top to just below top of bottom
The glass is not broken ,all the glass and latch are there it's the slide track that is gone
94 4x4,01 Blazer
poster edge- plastic edge for holding a poster and a piece of plexi- or some thin small hardware store hose-split and slide on edge of glass then look in the metal section for a u shaped piece of channel stock
