1 - 14 of 14 Posts
Got a 2000 RPO code of GU6. That is a 3.42:1 rear gear ratio.
I'm looking for a limited-slip unit to swap in.
Does anybody know what size rear gear this would be?
Does anybody know what spline count the axle would be?
Who might?
Thanks
2WD? That should be a 7.625" gear and 28 spline axles.
The only different 2WD rear was a 8.5" but from what I hear is only avail with 3.08 ratio and 5 speed trans in 2WD.
8.5" is also on ZR2s, and an option on 4WDs
Get a Zexel-Torsen from SLP while they last! http://www.slponline.com/view_product.asp?PARTNUMBER=64501T
T/A drivin foundin member
older 1st gens have 26 spline 7.5's
Freak of Nature
How do you determine if you have an 8.5"?
I have a '95 with a 3.08 single track rear and a five speed. Is the pumpkin a different shape or bolt pattern? Do I have to pop the cover off and measure the ring gear? Thanks for any info you can provide.:thumbup: :confused:
No problem! :D
Guy at SLP said there was a tech article on the Zexal install on this forum. I can't find any tech articles on this forum. Did I miss something?
What I am looking for:
Ring -? carrier bolt torque
Carrier bearing cap bolt torque
Zexal center carrier housing bolt torque
Diff cover torque.
Get a new gasket, RTV or both?
What weight oil to use?
How much oil?
Thanks (Any idea if the Zexal cam on an 89 Firebird?)
You might have to register there (free)
I am already registered so the link works ok for me.
Discussion Starter · #14 ·
An LSD and Torsen do the same function.
Difference is an LSD uses clutches, which eventually need replacement. Torsen's have no clutchs.
i.e. Less you have too much $, or your LSD is failing, you don't need a Zexel-Torsen.
On the other hand, (there are 5 more digits)
If you have the basic one wheel drive spider gear differential, $99 is a bargain to get LSD performance.
Differential units generally go fo $350 and up.
1 - 14 of 14 Posts
