I wouldn't even know what they're worth. I do know that they're some of "those" S10 parts...wink wink, nudge nudge, say no more say no more. lol
I plan on letting CalTracs solve that problem when I get my LS installed.I wouldn't even know what they're worth. I do know that they're some of "those" S10 parts...wink wink, nudge nudge, say no more say no more. lol
If I went with an economy LSD like I have seen such as a Spartan for under $400, or a more expensive one like a Yukon or Eaton, would that be just a slap in with not much labor, and would that eliminate having to also install a bearing/spline and carrier rebuild kit?I plan on letting CalTracs solve that problem when I get my LS installed.
That depends on what is causing your noise. If it is because of a worn ring and pinion then you are looking at a complete rebuild. If it is a bad bearing then that is another story. A reputable drivetrain shop should be able to inspect it and tell you what you need. I don't know anything about the Spartan but I know Yukon wasn't too pricey at first but when they got established their prices went higher than everyone else's. If you want a conventional limited-slip Eaton is probably the best value but I think the Tru-Trac isn't much more. I just looked at The Spartan and it's what is called a lunch box locker that is designed to go in an open differential to turn it into a locker. You would have to replace your Gov-Lock with an open carrier so that would cancel any savings. Spartan locker $432 Tru-Trac $425 to 497 on EBay.If I went with an economy LSD like I have seen such as a Spartan for under $400, or a more expensive one like a Yukon or Eaton, would that be just a slap in with not much labor, and would that eliminate having to also install a bearing/spline and carrier rebuild kit?
Thanks, but that one come up at $425. Would that just slap in if no other issues? I would take it somewhere to confirm of course and get total cost estimate. My budget is under $1,000. If I could repair what I have for under $500 total that would be good. But, if I could upgrade and still have it under $1,000 I may go that way!Not a Tru-Trac but same design.
Chevy GM 8.5" 8.6" Rear 1999+ Truck Differential 30 Spline Limited Slip Truetrac | eBay
Find many great new & used options and get the best deals for Chevy GM 8.5" 8.6" Rear 1999+ Truck Differential 30 Spline Limited Slip Truetrac at the best online prices at eBay! Free shipping for many products!www.ebay.com
I also found Eaton limited slips for around $275 on Ebay.
You need to talk to a trustworthy drivetrain shop for those answers. You will need new bearings at the least to swap carriers. noisy rears are usually either bearings or ring and pinion problems.Thanks, but that one come up at $425. Would that just slap in if no other issues? I would take it somewhere to confirm of course and get total cost estimate. My budget is under $1,000. If I could repair what I have for under $500 total that would be good. But, if I could upgrade and still have it under $1,000 I may go that way!
