On the original post I mentioned the first thing I did before its initial service was change the oil. After taking it back following the first service at no additional expense, it was still not 100% but livable until last fall. I would not drive it when I can hear it from inside the truck. I haven't installed a rear end in many years and would rather pay someone if it came to that. A junk yard rear end tells no tales and may be hard to identify which one it is.Since you only drive it about 1000 miles a year and have been doing fine w/o limited slip or the hop shock, don't waste the money adding them now. Doesn't sound like you need or use either of them. If this was a performance build that would be a different story. I agree repairing your existing axle sounds like a waste of money since it's whined for a long time. Probably not set up correctly from the factory.
If it were mine I get a GU6 3.42 ratio out of a junkyard 2wd 4.3 98 up S10 and swap it in. Couple hours work and a couple hundred bucks. It'll likely out live the rest of the truck. I've only had one failure in 37 years of driving S10's and it was just the cheap azz G80 posi not working. Spent over $500 putting in a Zexel.
If it's not a loud whine just drive it. Since you use it so little it'll be years before anything actually breaks.
Maybe drain the rearend to check for any metal and put some Royal Purple synthetic gear lube in. That might quiet it.
BTW the fill plug on the side is not 3/8" and you can round corner it using one trying to remove it. Get a cheap 10mm drain plug socket off ebay and avoid a major hassle.
