can you change the gears in the rear end to get a better quarter time?
R rokyholler · Registered Joined Jan 8, 2002 · 41 Posts Discussion Starter • #1 • Apr 28, 2002 can you change the gears in the rear end to get a better quarter time?
B BurntByTheSun · CURL UP AND DIE Joined Apr 29, 2002 · 357 Posts #3 • Apr 30, 2002 if you have an auto trans stay away from the 4.10's.....overdrive kicks in too soon in 1/4's .....go with 3.73's, should be about perfect
R rokyholler · Registered Joined Jan 8, 2002 · 41 Posts Discussion Starter • #4 • Apr 30, 2002 i have a 5 speed
T Trey · Slowest Member EVER Joined Apr 29, 2002 · 596 Posts #5 • Apr 30, 2002 sure, higher the gear ratio, the better your low end will be.
D DropindaS-Mini · drag~N~spark Joined Nov 3, 2001 · 9,530 Posts #6 • Sep 3, 2002 thread moved to transmission and rear end moved
