I have a 96 2wd Blazer non pozi. I'm taking it out west where there will be a lot of ice and snow. Does the 4wd and the 2wd have the same carrier and the same diameter ring gear? Are the axles the same splines? I found a 2001 4wd with a posi. Is it possible to replace my carrier with this later model posi unit. also can I replace my drum brakes with the rear disc brakes on this unit?
