1 - 11 of 11 Posts
so after replaceing the intake gaskets on my 97 i had a problem with code p01345 cam/crank corolation after messing around with the distributer for a day or two i got rid on this code and now have a randome misfire code p0300 i scaned it with a good snap on scaner and im missfireing like crazy on cylenders 1 and 3 my truck only has 75000 miles on it are my injectors starting to go?
Make absolutely sure you didn't switch the two plug wires by accident. :eek:
Could be. I would pull the plugs for a look-see first though. How old are plugs, wires, cap & rotor?
all those parts are brand new and i checked to make sure the wires wernt mixed up and there not so im guessing injectors witch sucks becouse i just got it all back together and now ima have to tear it down again
Check for good spark on 1 and 3, then
Sorry to repeat myself but it's Friday!
Before you go through the trouble of pulling your intake maifold again, connect a vacuum gauge and check it.
If you have a steady needle (~16 to 21) until one of those cylinders fire, and it bumps down real fast (~1 or 2 lbs) then you don't have a vac leak, you have a loose, bad, crossed plug wire.
Registered (Ab) User
Since it is only those 2 adjacent cylinders that are misfiring, and you ignition system components are new, it could be the following:
1.) Crossed or defective plug wires
2.) Plugged poppet injectors.
You might try running a couple of bottles of Chevron "Techron" additive in your gas, or a can of Seafoam. Otherwise, click here for more info on the CSFI poppet injectors, and click here for info on how to fix them.
i got a marine intake it came with evrything fule rails injectors throtle body, sensors i think i might just convert it to mpi i bought it for a turbo build i was going to do on my 94 so ill probly just use it for this and make a 2114 later on when the time comes, is there a wireing diagram out there that shows wich wires will go to witch injector?
Autozone has wiring diagrams. Click here and see if this link will work for you.
1 - 11 of 11 Posts
