Truck has 75k on it, new fuel pump 55psi @ idle, MAP @ idle 10.3 (19 inches of vacuum). Tight Distributor shaft, newer cap, rotor wires, fresh plugs, filters, cleaned MAF ... runs like crap at anything above idle but is smooth when accelerating.
If i unplug the MAP she runs/drives fine sept a slight flat spot off idle but generally drives fine and doesn't smell rich ???
Im thinking its got a vacuum leak (not hearing any obvious vac leaks) somewhere making it go lean.
Anybody else encounter this kind of problem with their 4.3 where when you unplug the MAP she runs fine, would like to know what others found as the problem here ? thks.
Any ideas ?
Any ideas ?
