I need to find radiator hoses for the S10 drag race truck I am finishing up.
Stock V6 radiator, plenty of cooling since we run alcohol, and I need to get hoses from the radiator (both are 1-1/4") to the thermostat housing (1-1/2") and to the electric water pump with 1-1/2" outlet on the passenger side.
Top hose will need to be about 16-17" long.
Bottom hose is going to be a long one and I need to get it turned 180 degrees (approx) at the 1-1/2" end and then get to a 1-1/4 for radiator lower outlet. If I need to put an aluminum tube in the lower hose that would be fine.
Anybody figured anything out for doing that. Going to a parts store all they ask is what year and model???
Appreciate your help.
I'm pretty much running the same set up but have a different water out set up. I'm suggesting using a set up like I have in my Regal which should account for the different sizes(see pic). My inlet would have worked with a hose but my front bar for the cage interfered and I had to use a tube.
Banned
The radiator hose popped off when engine switch off but no heat was detected by sensors it is a prado 150 2010 why is that.
