9" strait pipes...
I read, but don't understand the whole rim width and section width thing.
rim width is the width of your rim
when you see rim width on a tire spec sheet, that is the range of wheel widths that the tire can be installed on with out being stretched or bulging.
section width is the width of the tire at the widest point where the sidewalls bulge out.
tread width would be the width of the tread itself, only what should contact the road, not to be confused with section width
Better post-em.
yes 205/75 will rub with a 4 drop, mostly the top of the front wheel wells...there are 2 bolts you can remove to make it less tire shredding but they will rub the inner fenders going over dips/bumps.
