1 - 14 of 14 Posts
bitch pleaze
i will be starting my body drop on my 94 sonoma soon and i just need to know how much inches it is to drag door. thanks
Still plays with sparks
quick tip...forget about inches....just cut off your rocker, tack two beams across the bottom of your frame, and cut the floor.....bodydrop it to where you want it, then measure it..not the other way around....just my .02 cents....
bitch pleaze
thanks man that does make alot of sense since it would be a bitch to go through all that ork and not have it where you want it.
Yea, makes the front end a little more difficult, but imo its beter to have it to where you want it and have to line things up than be able to drop everything a set amount of inches and not....jon
Draggin Body Member...
The way the firewall comes back together it really doesnt matter how much you cut out of it because your going to have to angle the filler plates, the back cab is the only place I can see where measurements are important. I just cut about an inch from the bottom and cut the desired amount of metal out and then dropped the cab down past the 1" area, and then pop rivetted and self tapped the lip to it, and then I just welded it together.
The one thing I cant understand is I marked everything 3.5" and I even measured the cut out pieces which were all 3.5" and I ended up with like a 3.75" or 4" body drop, the step filler plates ended up being 4" angled. Goes to show you that measurements dont mean everything....
down to earth
5" to the door
down to earth
Ol' Skool Member
what are the two beems on the frame for? are they running perpendicular to the frame? just to space the frame?
1 - 14 of 14 Posts
