i have a quick question. will the 2.2 motor stick out of a 94+ or fit under the stock hood with a 3.5 body drop? would i have to lower the motor some?
Premium Member
I do believe Jollygreenmini did a 3.5, but I'm not sure if his motor is sticking out his hood.
I <3 SPARKS
Since this thread is talking about hood clearance, etc, how much does the engine stick through on 4 3/4" body dropped 1st gen Blazers? I've got the 4.3.
i measured my front bumper and it is 3 inch to lay maybe 2.75 i just eyeballed the tape i wish i woulda checked the hood for clearence b4 i took it apart. do u think i willhave to cut some hood suports?
can i video tape you?
yes, you'll prolly have to cut the hood supports.
Cab, the air cleaner on my LB sticks out about 1.5" about..so that should give you an idea.
Mad man from michigan
if you drop the motor and get rid of the cast brackets, it will fit under a stock hood. other wise figure an 1 1/2 to 1 3/4 it will stick out
