first gen firewall cutting...steering column is in the way of the 3.5 inch section im taking out.....what do i do...go thru it?...go around it?...help please....ive been searchin for a little bit couldnt find anything...thanks guys...
take a look..
JIGGA JAKE
if you cut around it ....then your steering column will raise as the floor raises and you will prolly have to modify your dash board.....i was taught to if possible take the 3.5 section out else where or cut the whole mounting hole out and continue with your cuts and when you have dropped the cab and raised the floor....then study the firewall and see if you can graft the original mounting hole in to the firewall somewhere near the factory location....hope that helped....
