Right now I have 3 switches mounted on my dash for my front left and front right and to pancake.I have had a avs 9 switchbox since xmas that I have been wanting to install.On the power portion of the box should i just run a wire to the battery so there is a constant source of power?Also do i need to fuse that wire?
i ran it into the constant power wire on my radio harness, some guys disagree with that because if your stereo gets stolen or something like that, your without switchbox power
I didnt think the HU got a constant power though? Wouldnt if it you ran it to that remote wire that when the truck is off the bags wouldnt work?
I have my AVC-9 box to constant power, you don't want to stick the key to play or dump the vehicle. Just look for a constant under the dash.
the HU does have a constant, mine is running off of it and i dont know what "remote wire" your talking about is
aww man. Ok, the constant power stereo wire is yellow, and the ignition switched power is red. Both of which are 15amps I believe. maybe the ign is 10, I can't remember.
I got it hooked to my remote wire on my amp and the bags only work if the ignition is on.I need to find a constant power source.
