bumpin noma
I just installed my SD control arms and they are sweet, but my lift in the front is a lot less now. I knew this would be the case with 2b6's, drop arms, and drop spindles, but on the driver side it is not even untucking the tire all the way. I'm not bodydropped and am running 245/45/18's so about the size of a 20. When I first ordered my parts I ordered the regular cups, upper and lower. Now since I dont need the lowers, would ordering the 3 inch upper cups give me more lift? What size are the regular cups? Is there any way to get more lift besides putting on stock spindles or 2b7's (will probably put 2600s on later).
Afterhours Admin
the 2b6s are whats killing you right now, a large bag will help the most. your tires are a bit under 20s so switching to stock spindles will help a lot as well but thats a bit more work.
Prime your tires are quite a bit shorter, youll def want stock spindles.
