i am needing some input on help with my ac on my 99 s10 4.3 auto . I went to go use my ac yesterday for the first time this year and it wouldnt get cold. I figured it was probally low on coolant so went and bought some and filled it to the right level. But the clutch for the ac woudlnt kick on. I checked the fuses and all looks fine. Please give any input you have. THANKS
could of seized up on yah they tend to do that lube it and give it a few taps with a malet if its only been off for one season it should free up if not yah can buy replacment clutches for them but there a bitch to change sometimes
I would check the high pressure cut off switch on the back of the compressor.
Just find the two wires and follow them to the connector and unplug it and just jump the two and if the clutch turns on then you need a new compressor or you can do what I did on my last s10 and just cut off the connector and connect the two wires.
Good luck.
