Eksessiv Louisiana
what is the largest bag i can fit on the rear of my reg cab s10 with a mono-leaf setup and still keep my shocks in their factory locations? i will be using 3/8 valves with 1/2 line. i wanted to do F9000 bags but larry told me i would have to probly end up redoing the crossmember and relocating the shocks, so can i do a 2500 or 2600 bag back there?
thanks
Visual-Insanity.org
I would do 2500 all the way around. You can only do 2500's upfront and you can go with 2600 out back.... I've seen many many s-10 that lay frame and havent had any crossmember work done.
amatuer porn star
if you dont cut your bed your not going to lay out.you can go with a 2600 in the rear as long as your bags are mounted over the axle.but in order to do that your going to have to use a step notch.
