will i lay out up front with tube upper a arms sd cups re7s 215/40/18 tire?
also can you keep the sway bar?
BTR
You may have to pull your inner fenders out, I'm not much on tire sizes so I'm not sure...24 inches or less outer diameter and you can keep them. Yes you can keep the sway bar.
drag racer
no, you won't lay. i'm installing a 235/40r18 and i had to dehump the lower arms, cut the cups, grind the lower control arm mounts and frame. i still have to notch for the tie rods.
