WRONG!!!!!!!!!!!down2earths10 said:i draw big circles. make sure you start at the top and go down.
yea I gess you could call it a C.Myst said:yea I know in arc welding you move up and zig zag ...but when mig ...I always seemed to have a problem going uphill ...what about horizontal ... you do a
C motion?? and move it to the right or left?
in stick welding it all depends on the rod your using, ex...7018 rod..up 6010 rod..however you wantMyst said:yea I know in arc welding you move up and zig zag ...but when mig ...I always seemed to have a problem going uphill ...what about horizontal ... you do a
:stupid:KdawgS10 said:WRONG!!!!!!!!!!!
ALLWAYS weld uphill. as in start at the botom and weld up. it is a WELL known fact that welding uphill is stronger.
and I use a U for up hill![]()
same... i don't know if it really makes much of a difference as long as your penetrating.fiveinchbodydrop said:i ve heard uphill and i do it that way now, but ive done two downhill and never found a fault... for whatever thats worth
o ok so you dont pull the C weld you push it ok ...see everyone has diff ways ...1lowGMC said:When ever I go uphill on a vertical weld, the pool gets thick at the bottom and thin uptop. So I do downhill, and have no problems. On horizontal welds I always push the weld using a C motion. I'm using a mig/gas 220v
