Ford guy stuck w/ chebby
Anyone heard of or used them yourself? They are rebuildable and you can set the amount of tension.. saw them on jegs this morning.
I turn.
I'm running a Howe tall upper balljoint and it's similar to the QA1 - you can adjust them for wear and rebuild them or change the stud to a different length. I think I'd still go with the power performance ones. I'm running those on the lowers and the boot is much better for daily driving and they generally look more solid.
I am happy with the PPM stuff. Just saw these and threw them up there. Always good to see alternatives.
is a fungineer
From the Jegs link: Not for street use.
These are designed to be on race cars, the low/zero drag is so you get repeatable results in geometry change through suspension travel, and they're rebuildable so you can replace just the ball if you get in a wreck and break the stud.
AFCO, Howe, QA1 (and I think one more) make a version of them.
Huh. Never knew! but yeah I read the "not for street use".. so are so many parts though.
